I noticed that the curent version 9.2.047 only partially support SNMPv3. What is the plan to fully integrate SNMPv3 into the tools?
Thanks.
gbockelmann - are there tools that you would like to see SNMPv3 support in that currently do not have it?
Greg
For security reasons we cannot use anything less than SNMPv3. I went through all the tools and found that several do not support SNMPv3. Here is the list:
Network SonarSNMP SweepSubnet ListAdvanced CPU LoadCPU GaugeRouter CPU LoadSNMP Real Time GraphProxy PingMIB ViewerMIB WalkUpdate System MIBRemote TCP Session ResetSNMP Brute Force AttackSNMP Dictionary AttackThere are a few others that I couldn't test some because TFTP wasn't working (probably our security again).
For security reasons we cannot use anything less than SNMPv3. I went through all the tools and found that several do not support SNMPv3. Here is the list:Network SonarSNMP SweepSubnet ListAdvanced CPU LoadCPU GaugeRouter CPU LoadSNMP Real Time GraphProxy PingMIB ViewerMIB WalkUpdate System MIBRemote TCP Session ResetSNMP Brute Force AttackSNMP Dictionary Attack
Due to a recent security audit I'm in the same boat as gbockelmann. I can no longer rely on SNMPv1/v2 for managing switches and routers. When can we expect to see full SNMPv3 support in the Engineers Toolset?
We definitely plan on getting SNMPv3 support for the functionalities mentioned above; however, which apps and what version (of Toolset) are currently being determined.
Would it be possible for you to prioritize the apps in order of importance from your points of view?
