I created OPSEC connector
When I started it, internal warning appears immediately and no event is collected.
Can you give me a hand?
Thanks in advance
I've used these steps to get CheckPoint working in the past:
http://knowledgebase.solarwinds.com/kb/questions/3158/Integrating+Check+Point+with+SolarWinds+LEM
So, it appears that you have the Opsec Application setup correctly based on the screenshots. Did you set the one-time password in the Communication screen under the Opsec Application? What is the Trust State when you initialize the application?
Hi
I have same problem of this.
any update for the issue.
I also following CheckPoint KB:sk103855, but unresolved
thanks!
btw, LEM using 6.1.0
I just did a Checkpoint config, and the issue we ran into was that the policy had not been installed/pushed to the Checkpoint cluster. Have you saved all your config settings on Checkpoint?
Hi Curtisi
yeah! I sure did install policy on Checkpoint.
Environment have two production devices. for management and gateway.
The OPSEC build on management server.
And, I done successful open Checkpoint NG LEA connector.
but I got same error message
Does I need to setup the send syslog from management or gateway?
Thanks!
Is your client DN exactly as you copied it from the application settings?
This may be totally stupid, but I don't know that the connector can handle an application with a name other than "solarwinds" (all lower case). It may be that an app called "lem" will work, and an app called "LEM" will not. Can you maybe reset up the app with a lowercase name?
I think this issue has been cleared up.
Checkpoint connector for r75.40 SPLAT your post.
All uppercase and lowercase not usefully in my OPSEC sync.
Mixed-case is powerful work in CheckPoint R77.20.
