Does anybody know how to get the file association to PUTTY using IE8? I know firefox prompts to ask for the program to use when you type telnet:10.1.1.1 but if IE8 doesn't do anything.
You should find an installer to automate the process here.
IE: www.nilpo.com/.../FireFox: iiegn.blogspot.com/.../ssh-handler-for-firefox.html
I'm also still looking for a solution to this as well.
Though I believe to make this work, the Telnet protocol handler just needs to be turned on somehow in IE8. It was first disabled by Microsoft in IE7, but there were reg hacks for IE7 that do not work with IE8.
Anyone have any ideas?
Anybody?
Bump, having this issue as well...
HI All--
I'll mark this for the PM to get your issues addressed.
M
Did anyone find a solution to this problem? I'm having the same issue.
Thx
A quick Google (search term "open telnet in putty from IE") came up with:
http://www.twpsyn.com/archives/45
It's aimed at IE7, but I have tried it with IE8 and it worked.
