If the switch that Orion is connected to goes down, does Orion think everything is down beyond that switch? Thus sending out up/down pages when the switch is back?
Is your Orion Server Dual lan ported? If your network connection goes down to your Orion server the server will not be able to get to the DB (if the DB is on a separate server) and no alerts would be sent. I would say that every node would show node down if you had a console to the server.
I will assume that you were asking what happens with node status Alerts that are configured on nodes that are connected to a switch that goes down. If so, are you wondering what to do with those alerts, since they will not necessarily be truly indicative of the status of the node, you can simply configure the node alert woth a suppression condition tied to the status of the switch. In other words, if the switch itself is down, the connected node status alert will not fire.
Is that what you were after?
Is there a way to just select certain Nodes for alerting?
Yes, you can. If you use a Basic Alert (the simplest kind) , then you can pick from the list of all nodes in your database which one(s) you want the alert to apply to. If you use an Advanced Alert, then there are even more ways to limit the alert to one or more specific nodes.
I thought I read that Basic alerts are going to go away soon. Can someone from SW verify this?
Is there anyway to do that in Advanced Alerts? Here is where I run into problems with basic alerts. We have a ceullar modem connected to our main Orion box to send out SMS pages if a node goes down. I only want to send out an SMS for our Distro switches. So I like how I can select nodes with basic alerts, but what if those nodes aren't on the Orion box that has the modem? Do I have to have 3 modems and 3 versions of NotePager? I think the ability to select nodes should be something Advanced Alerts does. Has anyone else run into this?
Yes, you certainly can do tha twith Advanced alerts. I wouldn't think that you would need additional modems. The modem is only there as the device by which the SMS messages are sent, right?
In any event, as long as Orion can monitor the Distro switches, then all you have to do is click on the Trigger Condition tab, add a simple condition where Node Name is equal to or contains Distro (type that in the box). Then the alert will only fire if the node is a Distro switch.
