I would also like to know if this is possible.
Thanks.
APM should do that for you. It will monitor the response time to a webserver by sending an HTML 200 request and response.
How would I go about setting that up? Do you know? I have the Application Monitor monitoring various services on various servers, but am not sure how I can set it up to monitor the website. The site is running via IIS.
Check Pages 21 and 22 on this doc.
http://www.solarwinds.com/support/apm/docs/APMAdministratorGuide.pdf
Check Pages 21 and 22 on this doc.http://www.solarwinds.com/support/apm/docs/APMAdministratorGuide.pdf
I was looking at those instructions earlier, and my module is called Application Monitor, not Application Performance Monitor. I cannot see the options that are listed in the Admin Guide. Do I have an old version that does not support this? I am running Application Monitor 8.0.21 with Orion NPM 8.5.
Yep, you have the old version, now they call it APM.
APM is a new product, but all customers who had AM and were current on maintenance were automatically granted a license for APM. If, for some reason, you do not see APM in your customer portal, you should call Customer Service and they'll help you get that fixed.
