Hey all,
for whatever reason, I am no longer able to see any of my IPSLA objects in atlas so I can't add to maps. has anyone else see this issue?
thanks
On the GoTo we've discovered that the problem is on additional poller where NA was connected to. So the problem is not in NetworkAtlas.
Hi Larry,
As we are looking into this,I would like to have more information.
What version of IP SLA and NPM are currently running?Any recent changes like upgrades or update?
Have you been able to fix this issue?
not fix, but workaround, yes.
I RDP into poller and use atlas from there. for whatever reason, it does not show up in remote atlas installs.
Do you see any errors in NetworkAtlas log file?You can find the log in ProgramData\SolarWinds\Logs\NetworkAtlas\.When you connect from "remote" atlas do you see any orion elements at all?
Thanks,Denys
I don't see any log files for that, only for MSI install. I do see all the maps,nodes,interfaces. I just launched atlas again to ensure no logs produced. I'm running win7 pro 64.
I know this is an old post.. but what is the "GoTo"?
goto short for GoToMeeting, which is a tool SW Support uses to remotely view/control your systems over web.
Thank you..
