happy new year for all;;
please i need your help in this
by misake i deleted Engineers toolset from start menu, and when i tried to return it, it appears as a folder, which is not proper,
please if there is a way?
thanks in advance
You many just take this opporrtunity to install the newest toolset v10.9. It a nicer dashboard and has some new features. If you are on v10.9, just try to run the install and choose the repair option. This may be the easiest way to resolve the start menu.
Zak Kahl
http://www.loop1systems.com
It is necessary to install other toolset v10.9.. There is no any option to restore the previous one... Please help me to find this, restoring way.
www.plagiarismsoftware.org/
http://www.merriam-webster.com/dictionary/plagiarize
http://www.indiana.edu/wts/pamphlets/plagiarism.shtml
Try running SWShortcutRepair.exe from Toolset installation directory.
thanks for your reply
, when i tried to repair or uninstall Engineers toolset it gives me approximate 20 application i have to close,
and i dont know how to close them,
and i am using ver 9.1
thanks
thank you,
I didnt find this file, could you please send it to me ?
It may not be part of 9.1. You will have to download the latest version.
thanks mishal,
do you mean i have to purchase latest version?
There are couple options you have:
1) if you do not have valid maintenance, you can purchase a new version, or you can try to uninstall the current version, delete the remains, and install it again (as a clean installation).
2) if you have valid maintenance, download the latest version from customer portal, and install it. Or contact our support.
thanks michal,
will see what i have to do
thank you
