The Global Config Search doesn't seem to let you search for numbers (IP Address). Is this by nature or some kind of bug?
Thanks.
works fine for me in 9.5.1
I'm doing this search in the NCM web interface. What version of NCM are you using?
mhh, never tried in the web interface... didnt even know you could...
I did it on the server in the NCM program itself (version 5.5.2)
EDIT: sorry, dont know why I said 9.5.1 before... :P
Can anyone at SW verify this feature to be working? If so I will need to open a case to figure out why it isn't on my end. Thanks.
How do you even do this Global Config Search on the web interface?
I cant seem to find anything to do this.
Are you looking in Orion or the standalone web interface for NCM? I can only find it at the following address ncmservernameoraddress:8888
Jeff
Should I just open a case?
