I would like to remove THWACK from the "NetFlow Traffic Analysis Summary " - Page...
How to do this?
Thx
Leo
Solved:
Use Customize in NPM Menubar, manage Views, choose NetFlow Traffic Analysis Summary remove THWACK...
Click on "Custimze Page" in the upper left hand corner and just delete the resource on that page.
Thx for the quick reaction, but:
...then I have to ask in another way:
What possible reasons could there be, that there is only a button "Netflow Settings" and no button "customize .... "
The Customize Button is missing...
Thx,
Lhuesker, may I ask why you want to remove thwack? You're making me cry! ;-)
Hello Allison,
to make nice woman cry, is the least thing i would like to do...
Here is a really good reason:
Almost every server we install SW at customers sites has NO connection to the internet for security reasons.
(Think on stored SNMP-credentials, credentials for enable-Level in NCM for example.)
So, there is nothing from THWACK to see on that pages. I don't know if it is in actual version still the matter, but the loading time decreases significantly if you remove the THWACK from the home-pages if there is no internet connection.
This is the reason.
To make You smile again:
SW-Support via a forum which is really read by staff and support like THWACK works, is the fastest most reliable (and cheap) support you can provide.
No vendor - except those you pay a real bunch of money - has a so quick, fast and engaged support! I like this!
Have a nice day,
Ok, I've recovered my composure now. No really, thank you for the explanation and the feedback! Glad that thwack is helpful to you.
I just wanted to follow up with you...since you don't have internet connectivity, are you using packaged help? Are you aware of this option?
