quote:Originally posted by asl-supportassuming you have a current support contract you can download the Orion Account Manager tool from the additional components section of the SolarWinds customer area at http://support.solarwinds.net/supportYou will need your ID and password to login.The tool needs to be installed on your Orion server.Analyser Sales LtdSolarWinds Premier Partnerwww.asl-solarwinds.co.uk
quote:Originally posted by Josh StephensThe Additional Components like the Account Manager are still being updated for v8 and aren't currently available for download.A quick workaround is to use the Database Manager to edit the Accounts table and delete the admin password. You can't read it here, as it is encrypted, but you can delete it. Then you can login to the website and reset the password.Thanks,Josh StephensSolarWinds R&D
what in particular for v 8?
Per Josh back in Janurary..."The Additional Components like the Account Manager are still being updated for v8 and aren't currently available for download."
In particular I'm looking for Account Manager add-on for V8.BB
Bryan,
I think Josh mis-spoke. The Account Manager functionality is now built in. We don't plan to ship a v8 version of that component.
Denny
Other functionality in that tool is built in. To reset the admin password, you are correct - delete the password with a SQL tool, which makes it blank. You can then change it from the web console.
