I seem to remember once seeing a thread post asking how to change the logo that appears on reports. But, I cannot find it now.
Does anyone know how to do this, or can you point me to the previous thread that talks about this?
Thanls.
This feature was added in 8.5. You can find the how-to steps in the Admin Guide:
www.solarwinds.com/.../wwhelp.htm
Before you start searching:
Thank you very much.
Should this work for automated reports and on the web site? It seems to me it only adds the custom logo on reports generated directly from the Report Writer.
Bo
Will I be replacing an existing "ReportHeader.jpg" file? If so, I cannot find a file by the that name in the Solarwinds/Orion folder.
The file did not exist for me.
Bo,
are you using 8.5?
dcl
Yes. I am on the most current version and service pack.
I am using version 8.5.1, and did not find the ReportHeader.jpg referenced earlier. Still waiting on a resolution. Thanks.
