As of version 1.5 can you import subnets into IPAM like you can the free IP tool?
I am waiting on this functionality to purchase IPAM. I have over 1200 subnets all over the workd I cannot add them all manually.
Hello Donald,
We can import subnets en masse. Import them with the free tool, verify the imported subnets are as you'd expect, then import the free tool database using a utility we ship with IPAM.
Here's an article on how import from the free tool.
http://support.solarwinds.com/kbase/ProblemDetail.cfm?ID=1141
Let me know if this works for you.
Is it just me or is that a hoakey way of doing that? Should the tool you pay for not be able to skip the middle man?
Hi Donald,
It is a little hoakey. The steps involved are definitely a productivity boost, so the feeling dissipates quickly.
I've provided guidance a few times for this process, and each time I mentally bring up the R&D time spent on things the community ranks higher. I do spent time after hours helping the product along, but always respect that ranked list.
Give the process a try, follow up with your experience. Brandon, our PM, weighs in all this stuff on the forum to keep that list up to date.
From a PM stand point, as ya'll have said, this is hokey and I have this up there on my usability issues list based on feedback from ya'll.
OK I just tried this and I have to say its not at all a good solution. Yes you can import subnets en mass but you cannot really. Sure you can pull them in but one, you cannot assign a subnet mask to it so how IPAM knows what the subnet is I am not sure unless it tries to fall on the 0 as a marker. Secondly, you have to assign subnets to a parent one by one. I imported 500 subnets and have thousands more so that is not really feasible.
Am I missing something here?
Has there been any dates set to release a revision that improves this functionality? I have hundreds if not thousands of subnets to import. Even with the current steps, it's very time-consuming, tedious, and not a viable option in my opinion.
See this post here
