Hi All,
Please let me know how to create a n admin account in patch manager . I have been trying this for two days but only getting failure.
Please provide solution or a proper procedure.
Any help will be appreciated.
Regards,
Ishant Walia
Its really simple IF you know where to look for it.
On the left its under Patch Manager System Configuration, then Security and User Management, then the tab for Security Roles. Then click on whichever account type you want ( I assume its Eminentware Enterprise Administrators )and on the right click Add
Navigate to your AD account and add it and save
while doing this an error occur. Please check.
It looks like your adding a local account? Try it with an active directory account. I don't believe a local account would do anything for you. Are you trying to set someone up with an account to use the patch manager console on a different computer?
please tell me the steps to create an AD account.
getting this error. Please help.
At this point ill suggest contacting solarwinds support because im not sure what you are trying to do. Also if you dont know how to use or create an active directory account they may be the better place to ask.
