Can you tell me how insert poller engine´s name in "node details" view ?
If you log in as admin and look under Views, select Manage Views. Find "Node Details" in the list and highlight it. Then select Edit. This will take you to the Customize Node Details page. You'll see all the resources listed in each column for the Node Details page. Click the green plus icon next to the column in which you want to add the Polling Details resource. This will take you to the Add Resources to Node Details Column x page. Expand the Node Detail Reports - Resources that Apply to a Single Node and find Polling Details in the expanded list. Click on the box next to Polling Details, scroll to the bottom of the page and click the submit button. That should add the Polling Details resource to the bottom of whichever column you selected. Let me know if this makes sense or not.
contracer,
If it isn't already there, you can customize the node details page and add the "Polling Details" resource to that page. I thought the Polling Details resource was there by default, but maybe not. In my environment, the Polling Details resource is in the left hand column on the node details page beneath the Event Summary resource. The first entry in the Polling Details table is the Polling Engine's name and IP address.
Hope this helps!
In my Orion I see this:
and I don´t know how insert "Poller Engine"
There is a polling details resource that is typically on the node details page which lists the polling engine
But how insert this field ??
Thanks a lot. Now works.
Is there any way to remove the "location" line in node details ?
No, not unless you modify aspx code yourself
