Does anyone know what eSpeech is? One of my users is connecting to my Exchange 2007 server and the 'application' is eSpeech. Thanks.
App Router Interface IngressBytes EgressBytes Bytes IngressPackets EgressPacketseSpeech RTP Protocol (8417) 62.9 Mbytes 61.4 Mbytes 124.3 Mbytes 51.619 K 45.783 K Endpoint Router Interface Ingress Egress Ingress Egress Bytes Bytes Packets Packetschi-srv-exch.lbmst.local 63.2 Mbytes 61.6 Mbytes 51.577 K 45.815 Ksea-sales-04.lbmst.local 62.6 Mbytes 61.4 Mbytes 49.421 K 44.704K
Hi Jason--
It appears from its website that E-Speech is a name pronunciation software, among other things.
What are trying to do so I can get you an answer.
M
Hi Marie,
Thanks for responding. I am just trying to figure out why one of my Sales people is connecting to my Exchange Server and downloading hundreds of Mbs using something called eSpeech. I would like to disable it. I don't see anything called eSpeech or E-Speech on my Exchange Server.
My guess is that 8417 is the client source port and NTA is miscategorizing it based on that. If you run a "netstat -b" on the client and server you should be able to figure out what processes are using the port. Failing that, try a packet capture.
I will run the netstat -b - thanks.
All my Exchange users are coming in on port 8417. Only difference is this specific user is using Office 2010. Maybe NTA doesn't recognize Office 2010?
I believe that NTA does application mapping based only on port numbers. My installation doesn't have anything by default for 8417, so I'm not sure where that's coming from. You can change it in NetFlow Settings-->Application and Service Ports, however.
