I need to add 200+ entries into a custom property pull down, is there a was to do this en mass and not individually? Thanks!!!
Have you seen the Custom Property Import tool?
Settings --> Manage Custom Properties --> import Values. This will allow you to import CPs from CSV, XLS or TXT files (with some examples files to get you going).
I did have a crack at updating the CustomProperyValues table (in test and dev), but the updated rows did not show up in Orion.
Hi cwjohnson3rd
You could do this by directly inserting the data into the Database in SQL.
INSERT INTO [dbo].[CustomPropertyValues] ([TargetTable],[Name],[Value]) VALUES ('NodesCustomProperties','Your_CP_Name_Here','Your_Entry_Here')
I have assumed it is a NodesCustomPropery, if that isn't the case then change that part of the command to Interfaces etc.
However, the OrionSDK has an API which lets you create Custom Properties with Values Managing Custom Properties · solarwinds/OrionSDK Wiki · GitHub
I tried this, but the values did show up in Orion.
Is there a second step required?
It works fine in my lab, the Custom Property did already exist though. Maybe that's the missing step for you? I was just adding value's to an existing CustomProperty.
Odd me too, I added a further 4 rows to my Customer CP, but when I went back into Orion (Node edit) the newly added options where nowehere to be seen.
Let me test it further...
Thanks, I will try this and see what happens
These are all pretty complicated.... you could just remove the limitation, import properties to nodes that need them, then turn the limitation back on and it will automatically include everything that exists on any nodes. I literally just went through this while merging two environments this morning.
This is the obvious choice, it maybe I misread the original brief I thought OP just wanted to create the options there wasn’t the added criteria to assign them to a set list of nodes but maybe that is the case?
The custom prop is already created... I need to populate the pull down for it with about 250 entries. I would have to do that individually via the edit custom prop selection. I don't like the Server Engineers that much...
Yeah I would just export out all the server engineers nodes and that column, tell them to fill out the spreadsheet, then when I get it back disable the restriction and import their list, then turn it back on and it will include all their values. This also has the added benefit of offloading almost all the work to them. Adding 250 values to the list one by one is a fools game.
I think that is the best solution...
Sounds like you had a good plan of approach, sometimes automation takes longer than just doing the task manually I guess it depends on how many times you will ever need to perform such a task
Good luck.
