Is it possible to create a package to push Office 07 via Eware?
As long the installation is a single EXE, MSI, or MSP and can be installed completely silent, then yes.
Ok, well let us know here how that works. I am also looking at an Office 2007 workstation installation via Eminentware.
Office 07 is not a single exe, msi or msp.
Hi Oscar,
although not directly supported until the next version, you can have multiple files when creating a package in the current version.
If requires some manual copying of files to the eminentware server in the packages\<office_package_id> directory.
This will package the contents of the entire folder.
To create a silent install for Office 2007, have a look at this link...
http://www.msfn.org/board/office-2007-silent-install-t89323.html
<snip>
Edit: sounds great David. I hope to be using this as well one of these days.
It is completely possible.
Please see the post before this.
Also, if you want you, you can create a self extracting exe with all the necessary files (if you need more customization.)
I like the Chilkat Self-Extracting creator personally.
Once again, quite possible.
