I want to monitor a Windows 2008 R2 server process and alert when a memory usage limit is reached. How do I do that?
Is this what you want?
Hi Mark,
you can try to use 'Component monitor wizard' and 'Advanced alert manager' for this.
1) Orion website -> Settings -> SAM settings -> Component Monitor Wizard -> select Process monitor - WMI or SNMP (screenshot) -> ... finish the wizard
2) Run 'Advanced alert manager' -> set a new alert or use predefined 'High Physical Memory Utilization with Top 10 Processes' (you can edit its trigger condition)
That kind of thing, but I want to be able to say when process x = 700,000K used send a alert, rather then on the percentage of memory usage.
Thank you for the information it has helped alot. If we have mutiple processes with the same name running does it combine the memory used by say all three process for example ot just reoprt on the largest one?
You are right, it combines statistics from all processes with the same name. You can filter some of them out via 'Command line filter' option.
Just one note, there was an issue in SAM 5.5 that MinMax charts didn't display correct historical data in this case. It was fixed in SAM 6.0.
Thanks for your help, how to I get the variable ${MemoryUsed} to show as MB as this would be better for our applications team, rather than have to work it out.
