Hello to all
I am trying to set up an application monitor that simply runs a {select * from XXX} query and returns the time it took to respond
Can anyone help me on how to configure it??
Best regards to all
IIRC you might be able to just throw your whole query in there as normal and just rig it up so that column 1 is an integer, maybe something like
select 1, * from table
In the past I remembered that it would basically just ignore anything outside row1 column1 (stat) column2 (message)
Set up a SAM SQL User Experience Monitor, give it creds that can access the db, voila
SQL Server User Experience monitor
Hello and thanks for the reply
This is exactly what I have done until now, and I get error "Unable to convert query result", probably because the query returns a lot of rows and not a simple number
Is there a way to bypass it? I am not interested in the results, but only in the time that it took to execute
Thanks in advance
turn it into a count(*)?
Not good, it optimizes the query and it returns the result very quickly
Good morning
It looks that this did the trick. Thanks a bunch
Minor additional question:The query returns a response in one quarter of time than it does in Management Studio. Any ideas why this happens
Off the top of my head maybe something like caching from previous requests, or if you used an agent on the SQL server maybe the agents report a faster response time with no network overhead, maybe you ran the SSMS queries from a different network location than the orion poller? Just guesses.
