Any input from SW tech staff on this idea?
What r u looking for?
BB
How often this works, any gotchas that are common, etc.. ?
Also wanted to know about transferring the license between the two servers: The manual states that you should use the Solarwinds LIcense manager software to do this. This leads me to ask the question: Does this mean both servers must have internet connectivity in order to transfer the license, or is there an off-line method?
Thanks.
I've had our dba move the db to a new server for me. I just ran the configuration wizard and it connected fine without any porblems.
The License Manager needs internet access. You may be better opening a support ticket and asking them to reset the license.
