Hello.
Where can i see information about CISCO device licences ( securityk9, hseck9 or another) in NCM or NPM database?
I need this information for one of my reports.
You can see inventory reports in NCM:
http://oriondemo.solarwinds.com/Orion/NCM/InventoryReports.aspx
NCM also has end of support and end of life details for Cisco devices:
http://oriondemo.solarwinds.com/Orion/NCM/Resources/Eos/EosMatching.aspx
\Derek
but I need feature of device ( cisco command like : #sh license feature).
Maybe you know SNMP OiD for this info ?
You could use the Universal Device Poller in the Network performance Monitor to do this.
Orion Network Performance Monitor (NPM) can monitor any SNMP enabled device. It has native support for a wide range of popular vendors and devices and as standard it will monitor a range of performance statistics such as CPU/Memory Utilization and hardware health on these devices. In addition, NPM can be configured to poll any OID available in private enterprise MIBs. This can be used to extend monitoring of natively supported devices to include non-standard Key Performance Indicators as well as polling devices that are not natively supported.
To do this, you will need to use the Universal Device Poller (UnDP) utility which is part of NPM.
The UnDP allows you to input an OID or browse the MIB tree for OIDs you wish to poll on your devices. You can then test and assign these pollers in bulk to your devices. The results can then be transformed if necessary and displayed in various formats in any Orion web console page such as the node details view.
The UnDP can be found on your server by going to Start > Programs > SolarWinds Orion > Network Performance Monitor > Universal Device Poller.
I have supplied some links to information about using the Universal Device Poller below.
I know how to use it. That's why i need OiD.
OIDView.org is a site I use when trying to find OIDs. Otherwise you can run an SNMPwalk of the device or contact the vendor.
Snmpwalk not seeing what i need. Contact the Vendor ? Maybe....
