Hello,
I have added some nodes to a group, some of them are missing now. I would like to know whether do we have any audit report to know the removed/missing nodes.
Raaga
If you go to Message Centre and select Audit, you will find an entry for Group member deleted/changed/added, which should help.
General piece of advice - use Dynamic queries in groups wherever possible and where I say where ever possible, I actually mean rarely should you use static selection.
Hello Roberts,
Actually to find the removed nodes by anyone from the team, we use audit events. But when I gave all the required input to find, there were zero results.
Please let me know if you have any idea.
Do you have other audit events being shown?
If not go to Settings > Web Settings and enable auditing in there.
If you have other audit events showing then may require a support case being raised.
In the settings page I could see that particular option as enabled. I am not able to see not even one audit event.
Through database manager and from "last 100 audit events" in report writer I could see the audit messages but not from console. What would be the issue. Please let me know.
Raaga,
Have a look in the database, this SQL query (when run against your SolarWinds DB) will show all the node related events, the when, who, what and which device.
SELECT aat.ActionTypeDisplayName
,TimeLoggedUtc
,AccountID
,aud.ActionTypeID
,AuditEventMessage
,NetworkNode
,N.Caption
FROM [SolarWinds].[dbo].[AuditingEvents] aud
INNER JOIN AuditingActionTypes aat
ON aat.ActionTypeID = aud.ActionTypeID
INNER JOIN Nodes n
ON n.NodeID = aud.NetworkNode
--Look in the ActionTypeDisplayName for Group related events and then filter them down by adding a WHERE clause--
WHERE aat.ActionTypeDisplayName LIKE '%group%'
That should show you what you are looking for, if it doesn't ensure that your Web Console Settings has the following enabled (as per m_roberts suggestion):
I hope it helps
Rich
Thanks for the help but still I donot see any event in database manager but nodes are missing from the group.
If you run:
What do you see?
If you see nothing, then try:
This should list all the audit events, if you are still not seeing any, then it might be time to make contact with SolarWinds Support.
Check the account you are logged in is an Admin, as this account permission is necessary to see audit events. If you are not, then this is probably why.
Thanks for the shared information. I am an admin and I do login as an admin into the application. Need to consult with Solarwinds support people.
