Hello,
I bet there is already a thread on this but I was wondering if you guys had instructions on how to integrate Scrutenizer with solar winds NPM. Thanks in advance for any help
It was a few years ago but I did that for a client. I found instructions on their site to do it before.
Here is what I found just now. It was pretty simple if I remember right.
http://forums.plixer.com/how-to-integrate-scrutinizer-with-solarwinds-orion-t1695.php
Thanks mdriskell, I will try that out
Hi Mdriskell,
When I try to run the command in the instructions I get the following error message
"Msg 4060, Level 11, State 1, Server MADHFSVNPMTI01\SOLARWINDS_ORION, Line 1Cannot open database "NetPerfMon" requested by the login. The login failed.Msg 18456, Level 14, State 1, Server MADHFSVNPMTI01\SOLARWINDS_ORION, Line 1"
I tried to go into the solar winds configuration wizard but could not figure out which login to use. Any suggestions for this? Thanks again
Hi Mdriskell,When I try to run the command in the instructions I get the following error message "Msg 4060, Level 11, State 1, Server MADHFSVNPMTI01\SOLARWINDS_ORION, Line 1Cannot open database "NetPerfMon" requested by the login. The login failed.Msg 18456, Level 14, State 1, Server MADHFSVNPMTI01\SOLARWINDS_ORION, Line 1" I tried to go into the solar winds configuration wizard but could not figure out which login to use. Any suggestions for this? Thanks again
I just ran the command again and took out the -d NetPerfMon and got the following error.
"Msg 208, Level 16, State 1, Server MADHFSVNPMTI01\SOLARWINDS_ORION, Line 1Invalid object name 'Resources'
Any ideas?
Like I said in my initial reply it has been years so I really don't remember the process nor do I have that product to test with. I found how to integrate the product from Plixers site and there were step by step instructions at the time.
If you are looking for the database login I suggest this thread
Look for Andy Coates reply as he shows you where to find the database user info.
ahh, ok, thanks for the advice
Hi
Did you try the External websites under admin?
/SJA
