Edit Network Maps On the Orion Map Maker , But in the WEB browse the Map sometime disappear sometime OK
What Problem ?
what does the web site show when the map is missing?
Can you post a screenshot of what you are seeing?
I clock Top 10 or Events or Overview button then review Home the maps disappear
THANKS every programer
good week!
I am having a similar problem where my map disappears after and then a reappears after a few minutes, leaving only the following message behind when the map is not there. Any help would be greatly appreciated.
Cannot load Network Map from "E:\Program Files\SolarWinds\Orion\Maps\CISCOVPN.OrionMap"
I sometimes get this as well. if I do a refresh, it comes back, but need to get that resolved.
Re-run the website portion of the configuration wizard, this should help.
How many elements are & nested maps are in your Map?
Are you loading this in the main page with other node info?Mapmaker is very DB intensive. Your map may be timing out before it can pull all the data from the DB.
I suggest loading the map on a dedicated page & reducing the number of nested maps.
what do you mean by "load the map on a dedicated page"?
Also, even if the maps are nested, why would that cause the system more cycles? I would think it would be easier because all it has to load at that point is a link to a map and not an actual object with all of its data.... Does it actually load all of the submap info as well? I would think this a very bad idea/way to do it....
