as soon as I enable netflow destination to my PC I get a fatal error with the new tool
"Fatal error: Input string was not in a correct format."
I've had no luck getting the real-time Netflow app to work at all. I get that error when I enter the IP address of a device. If I can enter in an IP address that it likes, then I get a "Netflow is not detected on the selected interface". I'm using a Cisco router that is reporting to Scrutinizer just fine. I added my workstation as a receiver of flow info and I still continue to get an error.
Its not supposed to be this hard!
First of all, I absolutely agree it shouldn't be this hard and we're working to resolve your issues. The error your are receiving is due to a known issue (see release notes), which occurs when adding NetFlow-enabled routers with noncontiguous interfaces. We will have a 9.0.1 patch release out very soon to fix this problem.
If you're having issues getting NetFlow Realtime up and running, please open a ticket with support so we can track this appropriately. And, please keep the feedback coming. We really appreciate all your help!!
One question on your NetFlow error on the router that does come up without error, do you know if you're attempting to send NetFlow v9? NetFlow Realtime only supports v5 today.
Thanks for the quick response Chris. My configs specifically state version 5 in them. Unfortunately when I downloaded the software on Tuesday and read the release notes, there was no mention of the issue. After you mentioned it, I now see that the release notes were updated on Thursday. Guess I need to ask for some version control on the release notes since most folks wouldn't know that they had been updated at all.
How did that make it through the beta tests? Seem like that would have come up at some point. I know I was part of the first batch of customers to get 9.0 but I'm very surprised no one caught that in the beta program.
I'm going to open a ticket with support since I can't make the app work at all and this was really the most exciting thing about the 9.0 upgrade to me.
I am trying to evaluate the toolset and I am also getting this error. How would I go about getting the 9.0.1 patch then? If I download again will the trial start over?
JMP-
I would suggest contacting Sales and they could assist you- 866-530-8100
Any news on the patch for this problem? It would be really handy to get this fixed soon!
