Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
unmanage interfaces (on router)
larry.rice
how would I go about unmanaging interfaces on a cisco device.
I have a RAS Dialshelf and don't want to monitor the individual dial interfaces, but they've already been pulled in to IPM.
Find more posts tagged with
Accepted answers
All comments
Network_Guru
Unfortunately you cannot unmanage interfaces, only the whole node.
.... although, perhaps if you edit the interfaces table in the DB, you might be able to.
It depends on how the polling engine interprets this. It might be worth a try to see what happens.
-=Cheers=-
NG
larry.rice
Thanks for the reply. appreciate the info. I'll play with the DB.
larry.rice
Think I got it.
Right click device and select 'List Resources'.
Deselect Interfaces you are not concerned with.
In Map Maker and on MAPs they go away.
chris.conway
One problem with that Larry. You will lose all your stats for the interface
Analyser Sales Ltd
SolarWinds Premier Partner
www.asl-solarwinds.co.uk
iunderwo
The big side-effect to unselecting the devices is that you lose all of the historical statistical information, unless of course that was the goal all along.
// Ian Underwood - Network Engineering
// Boston Stock Exchange
larry.rice
good point. not necessarily the goal, but maybe livable, as they would all be admin ports, and I could use NAM or something for top talkers...but definitely a good point.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
