Is there a way to suppress telnet and web browse links that are shown when viewing the node details in NPM? I know our devices do not have telnet and http enabled and the links are useless but it makes other feel better if the links are not there.
No, not without crawling around the raw ASP pages. If you do decide to go that route, keep a copy of whatever you change. Running the config wizard will blow away your changes.
Got that. What about the set of integration tool icons and links near the top of the page? Thanks in advance.
You can turn those off and on by changing the 'Allow Integration' option in the account manager, per user. Again, non-configurable. =\
Thanks. I was digging around the asp pages for those and thought there must be an option to leave them off. Merry Christmas to you.
And to you my friend.
Mrxinu--you were on fire with you great posts before Xmas. Thanks for them and your good holiday cheer!
M
You're most welcome. I try to hop on here whenever they don't have me out in the field.
