Would like to know how APM to get APM to work when NPM switch over to hot-standby server. Encounter error when hotstandby server became active.
Thanks!
The Hot Standby Server is limited to NPM. It does not suport APM.
Okay, however, the SolarWind's website doesn't seem to work without the APM when it's failed over to the hot-standby.
Able to login, but the website mention APM missing. Is there a way to access the NPM portion of the website only when it's on hot-stanby?
At present, if there are APM resources on the NPM pages, you'll have a problem. If you take the APM resources off and keep them in the APM area, you should be able to use NPM on the HSE. We're going to make some changes in the next release to remove this restriction.
Glad I happened upon this message thread. So, Denny, if I have NCM and NTA also installed should I remove resources for those apps fom any NPM views as well, or will the Hot Standy play nice with them?
Yes, same principle applies.
Thanks, Denny. I think I may have historically confused the functions of a hot standby server. If I understand correctly, a hot standby can take over for any poller in your network, but it will ONLY assume the NPM polling. It can never do any NTA, APM, or wireless polling. Correct?
If so, are there any plans to come out with hot standby versions of the Orion add-in modules?
Correct.
