I have orion npm 8.1.0 installed. My website runs soo slow. Any ideas?
you can try
Thanks for the info, but that didnt work. It a hp g5 sserver fresh build. I am thinking it might have something to do with the setup
I would strongly recommmend upgrading to NPM 9.1 SP1. Web performance is much better in the current version than in 8.1.
Yeh. Thats a $3000 solution I cant afford right now.
Understood. If you're looking for more help, you'll get farther with more details about your environment e.g., -- hardware, database specs, load times by resource, etc.
HP PROLIANT G3
xeon 3.06ghz
2 gb ram
sql 2005
Igig memory
2K3 Standard
Your problem is the database is located on the same machine as the poller and web....and only 2gb of ram. Put the DB on another machine, and you will see performance spike. Double the ram and watch it only get better.
