I am attempting to search for nodes, but the LEM says "connector discovery is already running. Cannot run at this time".
I have searched for nodes before, but it has not been running for 24 hrs. Any ideas?
Do you see this at the bottom of your screen?
Once i logged off and then back in.... i no longer see that
Is it still giving you grief?
the message is still the same once i click "scan for nodes", i have opened a support ticket also just in case.
I'm having the same issue. Scans never seem to complete, even after days. I would like to know what the solution is if one is found.
thanks!!
i currently have a ticket open. I did mention that IT is currently adding agents to workstations, yet to determine if this is causing the messaging
