How much browser sniffing is done by the web console - specifically on the Node Management pages? Do you have any info on what browsers you've tested with?
Thanks,Justin
The fact that the node management section of the website works on 2 out of 3 of the browsers on this machine. I don't seem to have any config issues that would be causing things not to work, so I wanted to know if there was any browser specific stuff happening behind the scenes of the pages.
The browser doesn't do any browser sniffing except for where we've found errors. We build the web console following standards, but some browsers--IE 6, I'm looking at you!--don't follow standards very well. When we find something that doesn't work in a particular browser, we may fix it for a troublesome browser as a special case.
I use Mozilla Seamonkey as my primary browser and I can't seem to get the Node Management page to work on two separate computers. I get the page, but the + boxes don't show, and the check box functions don't work.
Just to be clear, we support Firefox 3, IE 6, and IE 7. We don't test against or support seamonkey or Opera. Nothing against those browsers, but part of how we keep the product affordable is by limiting support of various platforms to the most common versions.
