This method is checking if the SNMP service is running and since when.We have frequent errors on the SNMP-Service in Windows, so when you start the service after an error, NPM sees it as the node is rebooted, so the uptime is no longer correct. it shows 0 hours, and the server is up for 66days.There must be a counter in windows that counts uptime, in ticks, seconds, or another value, if you could use that reference for uptime instead of monitoring the SNMP-service it self would be great.It's strange that there is no correct answer on this forum although this is pretty important information of your servers.If anyone have suggestions, I would like to hear it!Thanks.
You are correct, Orion queries SNMP start values to determine uptime, which is faulty.
Do a search for a utility called UPTIME. You can put it in a batch file and write the resuluts to a test file. Or you could invest more time to dump the results to SQL.
This may provide you a more accure UPTIME result than ORION.
We marked this UPTIME issue as a flaw with ORION, but got back, that it is "function properly because we are pulling data from SNMP".
Hi Jussty,Thank you for your answer, I will test this, because uptime is important for us and strangely on a few servers SNMP keeps crashing.The most servers we are running are Dell servers, so I searched Dell in combination whit SNMP, and found someone that told me that "Dell Open Manage" is cousin this problem.. but we have a few HP servers as well, and thought that I had an error before whit a HP server.. So thats strange. So my thought on this is, that Orion is using SNMP at the same time as a different service, and that way this will generate an error. If the SNMP-service stays running, the uptime will be accurate enough. So knowing this my next question is.. Is there a way to control the exact polling time. So you can spread the load of the SNMP serice. Just a thought.. but hopefully it makes sense.. Thanks!
Assuming you're asking about adjusting the polling intervals, you can do so through the web console under Admin > Polling Settings (under the Settings section on the right).
Hi Gle,Your right about that indeed, but in this case i don't want to be independent of the SNMP service being up for 10 hours, witch will mean that the server is up for 10 hours.If the SNMP services crashes, witch happens allot on some servers, the uptime will not be correct. It's a going on problem and i keep searching for an answer.. but did not find any satisfied answer about this yet. Windows it self must have something where you can pull the correct uptime from. Anyway.. if only snmp would stay running.. my life would be easier.
