Hi, When I go to edit a node, I fill out the Location field, but not sure how they end up in the locations listed in the screenshot. How did they get there?
I see replies for some super technical questions, yet my easy questions get ignored. ????
What screen are you in when you took the initial screenshot?
I was trying to add nodes on the atlas. I had to add nodes individually because the grouping for locations was missing some but not sure how to get them all together. This can also be found in Manage Nodes, and selecting Group by Location.
It looks to me like this information is being pulled from Active Directory for servers... Cisco devices etc. not sure. Running an experiment with one of my Windows boxes to valid.. should have empirical data Monday to ensure things get replicated correctly and give me a "true or false" indicator... will let you know Monday.
Hmmm OK it does not appear to be in AD.. let me keep looking...
Thank you. This must be another design flaw. This example shows a "Location: that I can find no where else in the SAM, and it contains a server located two states away.
Also notice the 99 nodes in the "Uknown" location. It is not obvious where these can be moved.
