Has this subject ever been addressed in Orion or with a integrated product? I'm looking for a solution for Alert Escalation. It would be really nice to have it integrated and controlled by Orion.
See page 130 (or 146, depending on if you use the Acrobat page number to jump there, or the printed page number!) ofhttp://www.solarwinds.com/documentation/Orion/docs/OrionCoreAdministratorGuide.pdf
what you could do is set multiple actions, one that fires every 20 minutes to call the tech till it get acknowledged, the second with an action that is delayed 60 minutes (third call) that calls tier 2 till it get acknowledged repeating x minutes, and the third that is delayed 60 + x * tier 2 iterations, etc. making sure to check box the do not execute if acknowledged.
The acknowledgement is done through the website.
Thanks, it appears that Alert Escalation is now supported.
Next question, Is there are way to acknowledge via SMS text messaging?
Hi JPoehlman--
Yes, please see this blog
Thanks,DH
DH,
The blog post is very useful in setting up Alert Escalation and Pagegate SMS messaging, thanks. But I don't see how to ackloweldge via SMS. From what I gather, the Alert recieve with need to access the Orion Web Console to Ackloweldge the Alert to prevent further escalation. We are still using old dump phones for our IT Engineers and on-call rotation. Did I miss somthing in the posting on how to acknoweldge via SMS...keeping the Alert tracking in Orion?
Jack Poehlman
Hi Jack--
I believe what you are trying to do is filed as a feature request (see here). I don't know if this would meet your needs, but there is the option to acknowledge alerts via email. I would recommend searching through thwack as there are multiple threads that contain information on how to accomplish this.
Danielle,
Thanks for all your help. Yes, the feature reuest is exactly what I am looking to achieve. Lets hope it is on the near term roadmap. Any method the requires email leaves up open to issues is the mail server is down, or is not able to deliver.
Thanks again,
