Hi All,
we are trying to monitor www.google.com from nethpath ,but getting dns error .What will be the issue .Source is my NPM server .But in my server internet based url will go through proxy server .What needs to be done.
This will be a setting that will either be on the server itself or on setting you need to change on your proxy server.
Check out his link:
https://support.solarwinds.com/Success_Center/Network_Performance_Monitor_(NPM)/NetPath_graph_issue_Missing_Internet_nodes_where_connection_stops_at_internal_node
Also check out step 5 of this article
NetPath graph issue: Missing Internet nodes when connection reaches endpoint - SolarWinds Worldwide, LLC. Help and Suppo…
Also, if you can post a screenshot of what your netpath looks like today and then after any changes you've made from the above 2 articles.
Please help on this.
let's start with testing a non-web based path. Create a path going to an IP or Hostname of a remote router on a port it's probably listening on, like 22. See what we get.
Not working now also ,Hope it is will not work with trail licence.
Trial licenses of NPM are fully functional for the 30 days allotted.
Just for kicks -- have you checked your DNS configuration on the Orion server? It does state a DNS error at the top right. Can you nslookup www.google.com from a command prompt?
Is your Orion server sitting behind a firewall? Try taking a look at these links. What does a tracert, tracetcp, and psping look like when trying to go to this endpoint, and endpoint ports you're attempting to monitor?
NetPath requirements - SolarWinds Worldwide, LLC. Help and Support
NetPath endpoint port is closed - SolarWinds Worldwide, LLC. Help and Support
If you search for NetPath at Success Center - SolarWinds Worldwide, LLC. Help and Support, there are a few articles related to allowing this traffic through various firewalls if that is your issue. Also to get it to show up through a proxy you would have to add an exception to the proxy I believe for your Orion server.
Hi Praveen,
Try out a different source (not your NPM server) - a different PC maybe with the Solarwinds agent installed. Make sure you are able to access the internet from this PC. This will help you troubleshoot.
cheers
Hi Ravi,
i tried with different PC where agent is installed , now i am trying to check some port connection ,getting probe status error.
take dns out of the situation use ip instead so try 8.8.8.8 and use port 443 i assume you can get to the internet from a web viewer (chrome,firefox or IE) on your poller.
From reading, it sounds like you have a proxy in the settings of the net path there is a proxy section just add the required details
Yes tried the same .Probe status error
