Dears..
I have to install netflow in another server..can i install it in another server that does not have orion..and what is the process to that if not
Thanks for your really help
NTA requires an Orion server or an Orion extra poller.
Great question. I thought there was a standalone version of the NetFlow Analyzer but I'm not sure.
Anyway why does NTA have to be on a separate machine from Orion? Is it performance, access or something else?
I want it to be installed because the flow of the data..I Donno..I have a good dickspace..but does installing it on the same server affect the performance and the data usage??
The SQL Server performance is what matters the most. I don't recommend running Orion, SQL Server and NTA all on the same machine, but Orion and NTA on the same box works great for me.
Since the SQL Server is the bottleneck I recommend you use the fastest disks possible and a high speed raid array such as Raid 10.
But..anyway..I have already Licensed Netflow on the orion Server and the SQL on the same server..so Will I face some problems in the future ??
BTW..I'm using very fast server with high dickspace?
I forgot..More than 120 GB or higher
The size of the disk doesn't matter. The size of the disk determines how much information you can store, not how fast the information can be accessed (read/write). I would recommend 15k RPM SAS drives. Your RAID controller should also have a healthy amount of cache on board as well. At least 128MB but more is better.
