I must perform a software upgrade from Orion NPM 7.4 to Orion NPM 7.8.5.
Please could you describe me the correct steps to perform this task?
Thank you very much
Saverio
Verify that you have 7.8.5 in your customer portal (if not, you need to request it with a support ticket)
Back up your map & reports folders- and DB just to be safe-
Upgrade with the installer- on top of 7.4 (assuming this is not a migration)
Yes I've the 7.8.5.
Is necessary also a new password or no?
Do you mean a 7.8.5 license reset? Yes, you will need a new license to install the upgrade.
Since there's a topic on upgrades, can you tell me what steps i would need to upgrade from 7.8.59 to 8.5.1. I assume i would need to go through a couple of in between upgrades for DB compatability.
thanks
Since there's a topic on upgrades, can you tell me what steps i would need to upgrade from 7.8.59 to 8.5.1. I assume i would need to go through a couple of in between upgrades for DB compatability. thanks
Oh, great, thanks
