Cause I found for example some query from sys.spt_columns_view, I don`t want that to be displayed in the Top SQL report, how to achieve that purpose?
Thanx
Hany
Here's a great article showing how to exclude things from collection:
SolarWinds Knowledge Base :: Excluding a SQL Statement from DPA Data Collection
Note: please use with caution as sometimes things can start impacting you from a performance perspective that now you won't see because of the exclusion...
Thanx!
Unfortunately, there's no way I know of to exclude just a user in the pre-defined (canned) reports in DPA.
Here's a link for SQL reports which are really just queries against the repo. You could take these and edit accordingly.
Database Performance Analyzer
Are you looking for a specific report? Or was this just more of a general how to question?
Also, if you start excluding things from collections, they won't show in the reports any longer (moving forward).
No, I need to see only queries executed against user DB`s not the system db`s, how to do that?
Note that there is a major difference from excluding from a chart or report and excluding from collection!
Great point!
Well I followed what is mentioned in the KB article, I successfully ran this code: INSERT INTO con_qp_exclude (dbid, type, value, origin) VALUES (5, 'H', '2800065850', 'U'); as 2800065850 is the id of the SQL statement needs to be excluded (sys.sp_columns_rowset).
See, for me I have no issue with that, but the problem is that my manager is recievieng this report on daily basis, and he doesn`t want to see any system queries.
It will probably take some time now for the system queries to get flushed out of the report...
Thank you, could you please identify "sometime"? like it will take 1 week or forever , cause the system query still coming untill now
Can you confirm that the hash excluded is no longer being collected?
In the repo, run
select id, name from cond
-- use the id for the correct instance in question and substitute it for the <id> placeholder below
select izho, max(d) from consw_<id> where izho = 2800065850
Let's see when the last collection date was for this hash.
Gr8, its giving me this result: [2014-12-14 10:04:47.623], fine it means the last collection date for this hash was since complete 4 dyas ago which seems good, but it still coming in my daily report!
Thanx 4 ur help
Yeah, doesn't clean out old data. Either re-define the report to a shorter time period so that hash isn't included or wait until it ages out.
Another option would be to define the report with custom SQL instead of the top N and include all hashes except the one you want to exclude.
