compliance report do not change after taking remediation action to fix a critical compliance.
How To: Process for running Compliance Reports
1. Run Report on selected Nodes
2. Remediation action: manual or through script
3. Download the Configs for selected nodes
4. Rerun reports
5. Validate the delta's
odehabu Which compliance report does not offer the correct remediation action for you?
it issss offering correct remediation action , when accessing violation details and then " Execute Remediation Script on this Node " or all other effected nodes
nothing changes in the report even after updating it.
odehabu Once you execute the remediation script you will have to download the running configs again. Then rerun the Compliance report.
Thank You , alot
No worries, which reports are you running? DISA, NIST, PCI, Audits?
