Dears,
My CPU Gauge in Toolset 9.1 with Orion NPM 8.5 cannot define Devices types and it gives me a bad looking on Device CPU Usage
Please Help ASAP
This is Excatly what is Giving me: Cannot Determine Device Type
the device company name is Aperto
Please Help
Just to confirm, you are trying to create a CPU Gauge for an Aperto device, correct? The issue may be that the Aperto WiMAX device does not support the MIB we're using to query CPU load. Can you post a screen shot of what you're seeing when you add the Aperto device?
Dear clapoint,
Heres the Screenshot of my problem
http://aycu40.webshots.com/image/31319/2003686421469111154_rs.jpg
Please Help in this issue, what to do ??
Waiting for your response and thanks for Help
It is most likely that we do not have the MIBs for this device in our database. We can verify this if you could look up a value for us by performing the following steps:
OID 1.3.6.1.2.1.1.2.0Type OBJECT-IDENTIFIERUnits Access read-onlyStatus unknownValue 1.3.6.1.4.1.9.1.17 cisco2501
With that information, we can determine if our MIBs database contains your device.
Very Thankful for Your Help, my best Regards to you and this Forum !
If you provide us with that information from my last post, we can check if your device is in our MIBs database. If not, we can add it to our database for a future product update. Please let us know.
