Dear Thwack Team,
I have updated the syslog retention time from 60 days to 30 days. Currently the database size is around 55 GB. How much time will it take for database size to be reduced.
Thanks in advance.
You will need to check your database in SQL. Deleting data from the database will leave white space in the database. You will need to shrink the database in SQL to reduce the database file size.
E.g. (rough numbers)
Refer to @sturdyerde's post above.
The maintenance runs nightly at 2:15am by default (configurable under your Polling Settings). If you don't want to wait, you can manually run the Database Maintenance tool on the SolarWinds server.
During maintenance, any syslog data older than the retention period (30 days) will be deleted from the database. This will leave white space in the database file. You can shrink the database in SQL to reduce this file size.
@shuth, thanks a lot for your reply. I hope database maintenance does not involve any downtime? Since we are monitoring critical services so cannot afford any downtime. Would appreciate your update...
Thank you for the reply. I actually wanted to know what if i run database maintenance (orion server-> start -> database maintenance). Will there be any downtime?
and what if i shrink the database, will there be any downtime?
It's the same maintenance task so no, there will be no downtime. The application just allows you to manually run maintenance rather than wait for the scheduled time.
There should be no downtime while shrinking the database either. There may be an impact on responsiveness from SQL during the shrink but SolarWinds will continue to operate.
@haris_salim, please note @shuth's comment about shrinking the DB. Reducing the actual size of any DB is a manual process. Read through https://docs.microsoft.com/en-us/sql/relational-databases/databases/shrink-a-database to gain more understanding about that process.
Dear @shuth ,
Thanks a lot for your guidance. I have updated the polling settings and now the number of rows have reduced. But the DB size has even increased. It has increased about 5 GBs in the last 5 days where as no changes were made at our end. How can i shrink the database with out any downtime.
Should i shrink the database using the SQL managment studio? What do you recommend?
Regards
Haris
@shuth, thanks.
Let me try this and will update.
Bye
