Hello,
How to show logs from McAfee, when McAfee can't work for specific user.
Can you confirm which McAfee product you are referring to? LEM includes a support for a number of McAfee products.
McAfee Virus Scan Enterprise + AntiSpyware Enterprise
Version: 8.8.0
Do you have ePolicy Orchestrator deployed to manage Virus Scan Enterprise? If so, there is an ePO connector available: Integrate McAfee ePolicy Orchestrator (ePO) with SolarWinds LEM - SolarWinds Worldwide, LLC. Help and Support
Thanks for information,
I have connect ePolicy Orchestrator, what should i do next?
You'll need to configure ePO to send SNMP Traps to LEM and then configure LEM to receive those traps. You can view the steps here: Integrate McAfee ePolicy Orchestrator (ePO) with SolarWinds LEM - SolarWinds Worldwide, LLC. Help and Support
Any problems let me know!
Hi bro,
I have try your suggestion,
but when looking at sem dashboard there is unmatch connector, and not normalized as attached file
