I noticed that I had not recieved a google chrome update, and so checked the synchronisation process and found that it has been failing for a couple of weeks. If I manually attempt to connect to the path ('https://3pupcontent.solarwinds.com/Content/Fetch') it has a certificate problem, however I can still connect. The error I am getting is as follows;
Name: EminentWare Update Catalog Result: Failed Started: 14/03/2012 10:28:31 Finished: 14/03/2012 10:28:33 Type: Manual Message: Unexpected website connection issue when trying to download 'https://3pupcontent.solarwinds.com/Content/Fetch': The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel. New Updates: 0 Revised Updates: 0 ID: 7a7ba172-0deb-4cfe-bf01-df6d43ac998c Expired Updates: 0 New Security Updates: 0 New Critical Updates: 0 Expired Security Updates: 0 Expired Critical Updates: 0 Revised Security Updates: 0 Revised Critical Updates: 0 Products with Security Updates: Products with Critical Updates: Has Changes: False
Thanks in advance.
What version of the Extension Pack do you have installed?
From the EminentWare (root) node, click on Version.
1.72.218.2
No, that is the current version.
Please log onto the SolarWinds Customer Portal and submit a ticket regarding your certificate authentication issue.
Good Day,
Were you able to get this issue resolved? Thank you.
Greetings Jeff.
I believe the original issue (which was migrated over from the EminentWare forums site, so we've lost the identity of the original poster) was related to a customer-specific issue with the solarwinds.com SSL certificate.
Is your question one of curiosity, or are you experiencing issues with catalog synchronizations?
Lawrence,
I too am having the same issue and currently have a ticket open. I am able to download the cab file by accessing the following fromwithin IE as instructed by support:
However, I have to first click OK to proceed past the websitesecurity cert warning. I have also added the site to the Trusted Sites withinIE as instructed by support, but he results are the same. Thank you.
