I think the title says it all - is this possible?
Regards,
JP
I must be dense, because it didn't say it all for me ;-) Did you mean for grouping devices in the All Nodes resource? Or do you want the ability to see custom properties in Node Details?
Chris, forgive me for a question poorly asked.
In the Cirrus (NCM?) application, I define my custom properties, like street address, building, CLLI code, etc.I noticed there aren't any webparts or resources to view the online NCM custom properties. The only place right now that I can view these properties is on the gui application under "Edit Selected Node". I wanted to test the orion integration as part of v5, but I can't see the results easily =(
In 5.1, we've added the ability to group by custom property in the All Nodes resource and in operations on the Config Mgmt tab. Hopefully, that will make it much easier to see the results ;-)
It would be nice to see a webpart/resource similar to the "Custom Properties" resource on NPM, but grouping also seems like a great idea!
Chris, is it possible to create custom resources for NCM like we can for NPM? I don't see the same infrastructure under NCM that is under NPM, but there might be some kind of trick?
I'd like a resource identical to NPMs NodePropertyList.Resource or UserDefinedFields.Resource, but for the Cirrus database.
Our plan is to make custom property editing available in the integration module for NPM. Longer-term, our goal is to move to a common web infrastructure for both products to allow resources like you mentioned above to be put on both NCM views and NPM views.
Thanks, Chris.I've got some handy sql reports for now that can point issues to me.
