hi
i have configured Cisco IPS and LEM as per manual but i try to add Cisco IPS it didnt get add on LEM and get following message on LEM monitor window
javax.net.ssl.SSLHandshakeException: Remote host closed connection during handshake
What version is the Cisco IPS running, and what version is the LEM?
Cisco IPS 7.0 & LEM Trail version 6.2.1 , running trail version because if i get successful in getting CISCO IPS logs to LEM than will proceed to Purchase this LEM.
Can you send over a screenshot of the connector you're using for the LEM to connect to Cisco and the config of that connector?
i saw an issue that when i connect IPS with IPS Manager after apply credentials on IPS manager it prompt me to accept certificate that was generated by IPS , is there any way to accept IPS certificate in LEM.
need help !
It appears this is an issue with the 7.0 IPS software. It also appears that Cisco is at least up to 7.3 as of 2015.
Release Notes for Cisco Intrusion Prevention System 7.3(2)E4 - Cisco
Can you update your IPS and try this again?
