Hi All,
I want to see real-time traffic in interface of device and i select button for show real-time but it not respond so i enable all addon and active x control.
Thank you.
Do you have Engineers Toolset installed on your machine? For real time it leverages integration with toolset
im having the same problem, it seems to have broken after an upgrade
i also get an IE error when i click the graph icon: Wrong number of arguments or invalid property assignment (IE 7.0.5730.13)
No , I don't have. I will try install it and update again.
Hi bshopp,
I installed Engineer Toolset but it not work.
I use IE 8.0.7600.16385 and Window 7 64bit
The script error when i click real-time showing button in my picture.
Are you running IE as Admin? Dang UAC can sometime cause issues.
Also, does your account in Orion have the Browser integration set to true?
Do you have to buy the Toolset to get real-time?
Currently, yes you do. Orion polls at a set polling interval, but if you want to watch a link or device in real time, you will need toolset and you can leverage the Orion/Toolset integration
yes, i have toolset installed
yes, i have browser integration enabled
yes, i have local admin rights (IE)
this worked at one time but i get the same error as above. its never been important enough to me to open a ticket though since i just open the toolset bandwidth guage
same tonyled
and i can open the toolset bandwidth guage from tooset program and see real time traffic but i want to see in IE too.
