Hi, can someone please advise what is the latest version that can be seen in Solarwinds Catalog? I have 15.017.200053 still as the latest.
nope its just the 1 additional adobe catalog. I never paid much attention to settings but ive never had any users complain so i assume it keeps them. Get the catalog and have a look to see whats in it
15.023.20070 is the latest reader and acrobat version that I'm currently pushing. Feb 17th was the release date for those, and they came directly from the Adobe packages: Administration and Reporting---->Software Publishing--->Adobe Systems, Inc. Packages
Hope this helps
Hi Dang, thanks. On Thursday the support guys help me introduce a manual "External" catalog from Adobe. Is this how it is supposed to work? The out of the box catalog was doing fine until August, and then stopped updating. Is there something wrong with the default catalog?
thanks.
Hey rodri, The main difference is who publishes the patches, the one the support guys and I showed you, are published by Adobe, the other is published by Solarwinds.
That's clear. Just wondering if that is the case, then why the solarwinds one stopped updating on July 2016? At least for Adobe Acrobat Reader DC, not for Flash Player or any other Adobe Product?
Im sure kellytice has answered it before in detail but for myself, without logging in and looking, I know that the external catalog is where you want to get the updates from. The solarwinds catalog just has full packages? Or something like that, i cant remember but theres a difference and the adobe external catalog is where you want to get updates from 99% of the time.
Does it mean I need to configure external cats not just for Adobe Reader, but for every Adobe software that I have? Full packages worries me as long as the customizations can be lost, isnt it?
Thanks frgpugs. The Support team has given me the guidelines to install the external Adobe Reader DC catalog, and it was pretty good in getting missing updates for Adober Reader in PM. I have also manually tested the remaining Adobe packages and they seem to respect the customizations like "disable auto-updates". I will keep it as it is, it looks much better now, as long as I can see updates at least 1 week after official release.
