Is there an easy way to update all accounts so that they don't have access to IPAM?
Hello Jesper.
Check your email please. 1:1 email is the preferred method for this exact kind of advice .
Cheers!
Anybody? I really don't want to have to manually set 175+ accounts manually via the web interface.
I've sent Justin some "after market" instructions to try. Please let me know if that helps!
Thanks, Peter. Worked a treat.
Hey
I need this too - Do you want to share ?
Hi All
I´ve searched the forum, but cant find any information about delegated access in IPAM.
I´d like to delegate access for certain areas of the network to, in my situation, the local IT offices in each country.
We use IPAM as a corporate IPAM solution, but it´ll never get better trhan the date we input, thus local access is needed to validate / correct ect.
I´d love if i could select certain supernets / ranges and grant individual users access to theese segments with admin / poweruser privliges
Is this possible ?
Not at this time, this is an open enhancement request for IPAM. Right now the permission settings are global.
