I am trying to generate a graph on total packets transferred but the left side of the graph says "Mbytes". How can I get the number of packets? -Debbi
I just caught this today as well.
The view is wrong. go to admin -> manage views -> select interface details or any interface details page and edit that section. Change "select a chart" to min/max/avg packets in/out.
That should do it.
But this is a default choice off the left side of the interface page. It's not a resource I added to a page. Has it been wrong since the beginning of time? -Debbi
not that I noticed , I think one of the SPs might have goofed it...
I don't see a choice for "Min/Max packets in/out, only "per second". Perhaps I am looking in the wrong place? -Debbi
what version / sp are you running?
OK, I guess I had to create a Custom Chart, then I had chart editing options. I was feeling pretty brain-dead for a while.... Thanks!!! Debbi
I checked this three times. If I create a custom chart, and go into edit, and Select a Chart: Min/Max/Average packets In/Out, when I click "Submit", on the Interface Details page it displays a chart of "Min/Max/Average Packets per Second" What the heck? -Debbi
