I want to be able to get the pretty Application Health Overview item on a view, but want to filter the application by a custom property. Anyone figure out how to do that?
Attached is the object I am talking about.
Hi xpowels,
unfortunately there is currently no way to filter applications for this resource. We can create a feature request for you if you wish.
Dalibor
Yep, click "Customize Page", then add a View Limitation based on the custom property you want to filter by.
Kris Maxwell
Loop1 Systems
kris.maxwell@loop1systems.com
This is true, the only way around it is to filter the entire view for now.
is correct. This resource respects view limitations. I've still gone ahead and logged a feature request under FB182801 to allow users to filter this resource using SWQL filters like many of the other resources available in Orion.
Would an account limitation be honored in a situation like this?
Sohail Bhamani
http://www.loop1systems.com
Yeah, the account limitation is in effect as well. Just tested it out in the lab to confirm.
I'm trying this out but I've only been able to get it to work if I do a view limitation based on specific applications or specific nodes. I've also tried Individual Groups and Groups of Groups, where I've grouped the applications into sub groups, then wrapped them up into a single group, but those don't restrict it properly. Has anyone else seen that behavior?
Group based account limitations only apply to the "Groups" view, or other similarly created custom group views. They are not a substitute/replacement for custom properties.
